Need Advice on Exhaust Tips and Rear Skirt
I recent bought SLP Loudmouth exhaust and installed it. It sounds great, but I cannot put the tips on because they rub on the rear skirt. Will they get hot enought to damage the skirt if I put the tips on, should I leave the tips off, or should I try to find some smaller tips or some flat tips? I dont want to mess the car up, and I dont want to die from CO poisoning!!
Thanx in advance!!
Casey
__________________
1998 Z/28 A4 Arctic White
SLP Loudmouth Exhaust
K&N Filter
(Known Mods, Got the Car Used from a Lot)
"I Refuse to Have a Battle of Wits With An Un-Armed Person"
Thanx in advance!!
Casey
__________________
K&N Filter
Thanx in advance!!
Casey
Thanx in advance!!
Casey
Originally Posted by psykoTA
Sounds like you need to adjust the LM some. The tips should sit well below the bumper. I would at least have a 1/2" clearance from the bumper to the tips.
As far as adjusting them, where would I make changes, everything seemed to fit just right and seemed pretty solid once put into place. There is a clamp at the y-pipe, a clamp going up over the axle, and a clamp connecting the right pipe. Everything went right into the stock hangers, the original exhaust was not sagging at all and the new exhaust pretty much lines up where the original was, just the original had the flat tips and the LM have a big-*** round tip.
Thanx
Casey
__________________
K&N Filter
this may not sound like the "proper"way to do it,but try prying down on the pipe to get the clearance you need.stick a bar or a big screwdrider inside the pipe itself and put your weight into it,it will tweak some,maybe enough for the tips to clear.
