tsp true duals question
do the tsp true duals fit up to any headers like mac true fits and if i run a spohn or bmr torque arm with the reloction crossmember will there be a clearance issue with the exhaust and crossmember
TSP duals are designed for LT's like pacesetter and Hooker's. They are also designed for the stock TA because the X is right under the TA bushing, so no the TSP duals will not work the BMR or Spohn TA with the crossmember, but you can get custom TD's made around the BMR/Spohn, but you can't buy it off the shelf.
