ABS INOP light on and TCS not working. help!!!
this is "mulletwearingtadrive", for some reason i cant log out of my friends account and go to mine. anyways i have a 98 TA and a while back i lowered the car on H&R sport springs. since the install my TCS is always off and pressing the button does nothing and my ABS INOP light has been on.
can someone point me in the right direction as far as where to look to fix these problems or what areas to check out?
thanks for any help or info
If it started when you put in your new springs, it's probably wiring related.
Check the connectors at each wheel, and the big plug on the driver side of the underbody.
Good luck,
Bad30th
Good luck,
Bad30th
