loudmouth is now obnoxious mouth. help!
installed pacesetters/ory pipe,eliminated egr,and bolted on loudmouth i already had,[ ],and waaaaayyyyy too obnoxiously loud.its like a glasspack loud at wot.tsp recommended a moroso spiraltune muffler,have you guys ever heard this setup?im really curious what difference it will make.any help is appreciated.
High flow cats would be more expensive and more work to install, but would help an awful lot. Try a new muffler first though, and if it's not enough go with cats. (you will probably still have rasp, even with a new bullet muffler but it should be much more liveable)
A good friend of mine has the spirl flow (which is the Moroso muffler) on his mac/ORY pipe car, sounds pretty good...If you dont want any rasp, go with the Borla XR-1
I know what you mean. I have mac mid's, mac ory, with lm and it was fine till i put the cam in. I changed it out with the new lm II and it is much better. The original lm has no resonator, but the lm II does! The lm II is a bullet type muffler!
Yeah, the resonator canceled out some frequencies in the tone, and that was a main cause of drone. (That rymes ) Did very little to muffle the sound, just shaped it slightly. The bullet muffler muffles and cancels out sound frequencies too. Making it a more refined tone compaired to a resonator.
