Continual Charing problem
Continual Charging problem
I have had both the battery and alternator tested and they both passed.
The battery posts are fine, the wire that is screwed onto the alternator is securely connected, and the 4 wire plug is in the alternator correctly (just 1 wire used though).
I do have an amp connected to the battery, but the low voltage happens with or without it connected.
Right now, when I start the car, it sits about 13.5v, after about 15 minutes it drops to 13.0v and will sometimes touch the red area on the gauges, but that's the lowest it has gone so far. It randomly jumps up to 13.0v (once it goes under it). When I give it throttle it comes up a bit, but eventually goes back down.
Any ideas?
Any ideas?
that is crazy. have you just tried to disconnect the amp from the system, just for a day or so to see if that is the problem. that is where I would start. kinda wierd though. somthing is draining the battery that is for sure. what is doing it is another mystery. hope that helps.
But other times I love it Thanks for the help, keep it coming.
Matt
