drill crank bolt to get puller on center?
so the crank pully is being a bitch and is not coming off. i alreay fucked up a 3 jaw puller but kragens hooked it up with a new one. on the one i broke , the point got worn out and made a lot of scratches on the crank bolt too. i alreay got the bolt off by the way. so i was wonder if it was ok to drill a small hole on the head of the crank bolt so i can center the crank pully and get it off?
Originally Posted by 1BADAIR
I put an old socket on the bolt and use the square to center it
Originally Posted by 240M3SRT
I thought of that as well, but with nothing but snap-on tools that kinda rulled that one right on outta there
Autozone......$2.xx for a socket?
If you have a good puller with a socket it should come off. Helps to have a spare set of hands too.
