Where to get angled plug wires?
I need some 90 or at least 45 degree boots on 2 of my plugs in the '69. The headers won't allow the stock plug wires to go onto the sparkplugs. All I can remember seeing are the straight factory replacement ones. Surely someone with headers has run into this problem and can tell me who sells them.
You can check ouut thunder racing http://www.thunderracing.com
I also hear good things about http://www.elitesparkplugs.com/ they can make you what ever you need.
Hi if you are still in the market for ignition wires we can make any wire configuration you want and our heat shielded wires can take anything you can throw at them. (500 degrees direct heat and 1200 radiant)
And best of all you don’t have to cut and fit your own wires.
Thank You,
Elitesparkplugs.com
