Pacesetter LT/Sweet Thunder install......first impressions
Old 04-30-2005, 02:02 AM
99Hawk262's Avatar
Default Pacesetter LT/Sweet Thunder install......first impressions
Well, I did the install today. It took about 5 hours plus the two hours yesterday removing the old exhaust. Getting the old manifolds off was easy except for the passenger side rear bolt. What a PITA! Once it was off, the header slid in with no problems. It was almost scary how easy it went in. The driver side posed a slight problem......I had to grind the tab off the engine block before it would slide in. Once that was ground down though, no problems. I used the 24" o2 extensions and zip-tied them out of the way. Overall.......too easy!
Drove to the muffler shop with open headers, YIKES was it loud. I thought my car was going to fall apart. Got the TD's installed.......I went 2.5" all the way with an H-pipe and dumped before the axle. WOW! Hail to the SWEET THUNDER The sound is amazing, like jaw dropping. Certainly on the loud side, but very little drone and interior resonance. Sound good even on the A4.
Now for the fun......can you say SOTP difference!! Night and day. There is absolutely no lag off the line now. You hit the gas and wham, RPM's immediately jump up. And man does the car go Traction is a small problem, but nothing that can't be manipulated. And golly does she sing at WOT. Look out, here I come! I recommend this mod to anyone. A must do! Wednesday night will tell what the 1/4" gain was.
One last concern, the shop that fabbed up the TD's went immediately to 2.5" from the 3" collector on the header. They also had to crush the driver side pipe slightly to clear the floor. Is this bad? Am I choking my mostly stock car? There wasn't really any transition, just 3" to 2.5" like that. Not really worried, but don't want to be losing a lot of power because of this. There you go, my impressions. Sorry it is so long, I just wanted to get this out. Thanks
Old 04-30-2005, 03:13 AM
ZR2877's Avatar
Sounds like you have a nice setup. I have ST too and yes they are loud.
Old 04-30-2005, 09:22 AM
WS62000's Avatar
Is it possible to get a sound clip. I'd love to hear an H-pipe setup!
Old 04-30-2005, 11:46 AM
00Z28 Camaro's Avatar
yeah Id like to hear them too , are you on ls1sounds or anything ?
Old 04-30-2005, 11:54 AM
99Hawk262's Avatar
No I'm not. I'd like to post a clip though. If someone can tell me how to do that, I'd be more than willing.
Old 04-30-2005, 10:54 PM
67SS&99SS's Avatar
Just take a clip, and go to ls1sounds.com. You can email it to him or send it though a file transfer service. Chad can post it up for you. I am interested in hearing your setup as well. I have an A4 with single chambers and have always wondered what sweet thunders sounded like.
Old 04-30-2005, 11:14 PM
99Hawk262's Avatar
How does your exhaust go together? Do you have a transition from your header collectors to the 2.5" tubing? Or does it just neck down immediately behind your headers? Mine necks down immediately and I wondered if that affected the performance at all?
