another true dual question
Old 05-13-2005, 12:16 PM
evergreen0077's Avatar
Default another true dual question
im sick of not having tips with the TSP true dual system, so im gonna have a local shop fab up some true duals over the axle, with both (2.5in) pipes on the passenger side, do i need to puchase a new panhard bar or anything else to accomplish this??
Old 05-13-2005, 06:57 PM
someone that is running true duals out the back must know?
Old 05-13-2005, 07:18 PM
rollinna65's Avatar
check out the bmr panhard rod relocation kit, it should be exactly what you're looking for.
Old 05-16-2005, 09:33 AM
i know you need to use the bmr relocation kit if you want to run true duals, one pipe on the driverside and one on the passenger, but what about if i run both pipes on the passenger side, do i need anything then???
