QTP headers and y
QTP headers and y
I am going to go with the QTP headers that require removing the egr and air....Will this cause any problems???.....also I want to go without cats but i have to because of emissions.....is it possible to get the ORY and then later add cats??? Thanks
This will help http://www.ls1camaro.net/sections.ph...ticle&artid=70 ses light will come on get it tuned and that will fix the problem.
I would get the kooks y pipe. It has better fit. It will fit the QTPs I am told. You will need to do tuning to get the most power from you headers. You can get HP tuners and do it yourself. It is not that hard. The QTP header fit great. If you put them on make sure you put the car up High.
