Dual Cut-outs
Help!!!! Dual Cut-outs
Here's the break down guys...
I've got Kooks SS 1 3/4 Headers to a 3" collector. This runs out through the Kooks 3" ORY to a GMMG with a bullet in the I-Pipe. I just ordered dual QTEC electric cut-outs. I just got off the phone with the exhaust shop and they said they probably won't fit. Does anyone else have these installed with my Y-pipe set up? I don't want one in the I pipe. My car's already loud. I want it to SCREAM.
Hopefully something can be done because I've seen the QTEC Y with the duals right after the primaries but I have a flat cross section on my Y for clearance...any advise guys?
Thanks!
D
Thanks!
D
i installed a kooks ypipe this weekend and if yours tucks up like the one i installed there is no way the cutouts would fit. to get them to clear the floorboard you would have to angle them down so much it they would hit everything on the road
but your ypipe may hang down a little lower and give you more clearance
I know this isn't a kooks ypipe, its my 3" hooker ypipe. Im just giving you an idea or what needs to be done.
In the next pic is the qtp's ypipe. (if it doesnt show here, view it at their website) In my opinion their ypipe is not worth the money ($650). Any guy at an exhaust shop with basic fabricating skills should be able to do this to your ypipe.
I will second the qtp pipe not being worth the money. Just b/c you get the flowmaster merge...whhhooaaaa...what a steel. Have someone w/ minor experience custom fab you a pipe, thats what i did after making the mistake w/ buying this y-pipe. Its in the dump right now....500 down the tubes. Good luck.
