!FRA gains.
!FRA gains.
I performed this mod a little earlier today.. I can hear a difference and there is a little bit better throttle response..
man that plastic was a bitch with my dremel (didnt have the right bit)
what are the average gains? 3-4rwhp?
tomorow I'm gona try the TB bypass mod and to get rid of that thingy that is in the TB...
hoping for maybe 2more rwhp?
What thingy that's in the tb? Do you mean the piece that hangs down in the intake manifold behind the tb? With ALL free mods GMHighTech mag dyno'd 10 hp higher. tb bypass.tb porting, !FRA, intake "manhood" chop. Also, descreen the Mass air meter. Take it apart and pop out the screen. There's nothing but clearance (or lack there of) that holds it in place.
Originally Posted by SOM98TA
ok well I thought that the thing hanging in the intake was in the TB?
well I'm sawing that off and deleting the EGR stuff of the TB...
That thing that "hangs" in the Intake, with the tube coming out of it is the EGR...It takes gases from the manifolds, and puts it back in the headers to make the EPA happy... You're going to need to remove that and plug the intake with a freeze plug. Then use some block-off plates on the manifolds....
I have no idea what you're talking about when you say you're deleting the EGR stuff off the TB.
Also, you have FRA. NOT !FRA.
"!", means removed, not included, gone, etc....
Originally Posted by FBDYLVR
I get a really dirty filter w/ the FRA, I need to flip the K&N every once inawhile to get it evenly distributed.
Originally Posted by mellowyellow02
FLIPPING THE FILTER IS NOT A GOOD IDEA IT HAS A FLOW PATTERN AND ANY DEBIS,DUST ETC,ETC IT HAS COLLECTED WILL BE SUCKED IN THE ENGINE.
yeah your filter will get a lot dirtier, on a dyno it would show much of an increase because the air going into your intake would be significantly warmer and negate any air flow increase.
when i did the mod i noticed better throttle response and more noise from the intake, along with a lot dirtier of a filter.
