Fast (78mm) Vs Ls6
Originally Posted by Beast96Z
If yo have a bolt on car with a LS-1 intake, then the 78mm might be the way to go if you never plan on upgrading. If you think you can use the potential of the 90 later on down the road, just keed the LS-6 intake and buy the 90 later when it's needed.
Originally Posted by NickcZ28
Will The Fast (78mm)pickup Over Ls6
Just FWIW.
Mike
Originally Posted by V6 Bird
To say it doesnt pick up over the ls6 would be an understatement because I had Hooker LT's and 3" duals before with the LS6.
Originally Posted by Y2K SS
Don't think that came out quite the way you wanted it to. Is your car modded beside the Lt's??
Car was making 350ish before and made 396 at peak after all the swapping at the same time.
