single or dual cutouts???
Would I be better off w/ one cutout in the I-pipe or stick with what I was planning on doing. One at the end of each header. Would I loose to much backpressure to see any gains in the 1/4? Jet Hot lt's. Rest is in sig. Thanks.
i have lt's and ory and a single cutout in the I-pipe.
i think a single should be good enough, unless you are planning on running a true dual setup, the need for a dual cutout setup makes no sense. this is only my opinion.
not to mention that if you are going to get electric ones, they are 175 bucks a crack
