A/C Question
Old 07-19-2005, 04:34 PM
TTuRaider's Avatar
Default A/C Question
have a 98 Trans Am and the A/c Has started going warm. Went and got the R134a recharge kit from autozone and the can was barely getting cold... but the A/C was getting a bit cooler ... car ran for about 15 minutes and can wasnt even half empty... does it mean there is too much freon in the car already or should I just be more paitent and let it run longer cycling the A/C on and off??
help this A/C newb
Thanks
Old 07-19-2005, 08:49 PM
M6HuggerSS's Avatar
ac must be on high.
and if your system is to low you need to suck out the old air as you pump in the r134a
Old 07-19-2005, 11:47 PM
TTuRaider's Avatar
sucking it out just drain the beast by let all the air run out or do i need to get one of the hose things with the gauges
Old 07-20-2005, 09:05 PM
M6HuggerSS's Avatar
you need to take it to a shop with an evacuator so they can pressurize the system.
