Weird white residue from A/C
Old 07-31-2005, 06:07 PM
LS1LUNATIC's Avatar
Thumbs down Weird white residue from A/C
Guys,
Here in Houston, it is sickly hot. I know this is affecting my performance, but do you think it might affect my A/C? When I drive around with the A/C on and arrive at my house, or anyplace for that matter and the A/C dumps the condensed water, once dried up it leaves a white residue, like seriously white, almost like chalk. I know that when water dries up it leaves a residue, but nothing to this extent. Has anybody ever had this problem, or heard of it? It has to be coming from the A/C, nothing else leaks in my car. Any suggestions, opinions or what not are welcome.
Old 08-01-2005, 09:48 PM
01WS6/tamu's Avatar
Well you are right in once aspect it is either calcium or salt residue or a combination of the two. Being close enough to the bay it can be a salt residue mixed in with the humidity that is condensed out of the air. Don't shoot at me but, if you run it on max a/c it will recirculate the air in the car and cut down on the sticky outside air that the evaporator has to knock the humidity out of.
Old 08-02-2005, 07:33 PM
LS1LUNATIC's Avatar
Hmm, I appreciate your input, i still dont know what causes it, looks like I'm gonna have to try running it with reg a/c and max a/c, see if that makes a difference.
Old 08-02-2005, 09:19 PM
Sebring 00's Avatar
I agree 100%....... Seen it many times on cars that live near salt water or in high dew point areas.
Whats most important is that the A/C condensate drains freely. Don't matter what color it is.
Old 08-02-2005, 10:00 PM
01WS6/tamu's Avatar
The only thing going from max to outside air will affect is the comfort level of the vehicle and the amount of humidity condensed out of the air. The a/c has to work a lot less on max bc it is not pulling a 110+ degree air from the cowl behind the hood and then cool it as it goes through the evaporator. It will get colder and sweat less on a trip of 30 minutes or more on max. Around town you will usually be hard pressed to tell the difference except for the humidity level in the cabin.
Old 08-03-2005, 06:36 AM
bboyferal's Avatar
As long as A/C isn't someone's initials, the above assessments are adequate.
Quick Reply: Weird white residue from A/C
