ssra install????
Old 09-08-2005, 07:04 PM
Magnet's Avatar
Default ssra install????
im tryin to install a ssra and having a crappy time. i bought i off here so it didnt come with instructions....i got everything apart and then realized that there is a 'y' shaped brace right in the way??? what do i do with it? and also i already cutout the bottom of my air box for the fra mod and the ssra doesnt seem to sit flush or anything, it doesnt seem like it would seal.......
yes ive searched...everyone says tyo use the instruction that came with, and that its easy and straightforward.......
Old 09-08-2005, 07:13 PM
Dustin's Avatar
bolt that ****** down. As for the y thing, it should remove and bolt onto the ram air if i remember correct
Old 09-08-2005, 07:37 PM
Ru2n00n3er's Avatar
You put the top peice of the SSRA in from the top, so it sits above the y-brace. The other peice has a cotout in it that fits around teh y-brace as you push it from the bottom of the car into the other section.
Old 09-08-2005, 08:19 PM
Magnet's Avatar
can you use the ssra with the fra mod already done? or does part of the lower airbox still have to be there for it to sit properly and seal correctly?
Old 09-08-2005, 09:46 PM
Magnet's Avatar
just to let you all know i got it on......was simple once i figured it out lol
Quick Reply: ssra install????
