Which intake manifold ls6 or weiland
Was wondering which is the better manifold. I try to keep things cool w/ the coated headers and 160 stat w/ the tune to kick the fans on early.
So heat soaking shouldn't be too much of a problem.
Which manifold flows better? Does anyone know hp numbers?
Any help appreciated.
I personally wouldn't change. The only reason I'm swapping my LS6 intake for the Weiand is so I can polish it like the rest of the motor. Otherwise it would be a downgrade.(Performance wise)
They both flow the same as the Weiand was designed off of the LS6. The Weiand however, offers additional portability, direct port for nitrous and yes, a nice bling option .
Soon, the 'heat soaking bracket racer' crowd will be around to talk you out one and all of the 1-2hp loss you'll get from this mystery . Personally, if you're not opting to do any of the above, keep the LS6.
