Help w/throttle body and IAC
So after asking this question, I have come to belive that my IAC may be dirty. I replaced my Lid and Filter and cleaned up the throttle body with a rag (oil residue) and I believe that my idle and surging problem is from a dirty IAC. How do clean this? Do I use plain old Gunk carb cleaner with the engine off or on? Do I need a special cleaaner other than a degreaser? IPA Alcohol? Should I remove the IAC and clean it and then clean out the passage in the throttle body with something? Please comment.
Thanks
Nick F
Thanks
Nick F
Thanks all, it was a combination of some things, I believe. A dirty IAC which I cleaned with Throttle body cleaner. A damaged pulg wire on #8 and a cracked plug on #4.
Thanks
Nick F.
Thanks
Nick F.
