Help : FLP LT's w/ off road Y
Howdy everyone, just wondering if those of you out there that own the FLP Header/ y-pipe system could tell me about exchanging the cats and the offroad pipes. Right now im running through the cats, and i would like to put the off road pipes in. Is this easy or hard, if so what tools are need, and how is it done. Thanks for any input and/or help. Take it easy.
(Ive been lazy so i guess my next stop is looking on finish line perf. website for answers)
it is simple just undo the 10mm (i think) bolt on the 4 clamps then remove the clamps and switch the tubes. becareful when you put them back on not to over tighten the bc i snapped a bolt doing that.
Couple tips.
The clamp won't come off. Notice it has 4 'slits'.
Put a screwdriver in the slit and pry to get the clamps off.
When putting back on, go buy a roll of $2 aluminum tape from Lowes' and rap it around where the pipes meet before you put the clamp on. This will help with rasp when running the off road pipes. Trust me on this one; it just doesn't seal as well as with the cats.
