Dremmel tool to port TB??
just wondering what tools to use to port the stock throttle body? i was thinking about using a dremmel tool and sanding it down, woudl that work? or are there some other tools to use, need you help guys, thanx
That's all I used was a Dremel. I used coarse (can't remember the grit) and then worked my way to finer sanding drums until it was the way I wanted it. Then I polished it up with a the Dremel polishing kit.
