HOw much easier will plug change be w/o air & egr?
Originally Posted by 2000 TAWS6
Now that I have removed my air & egr systems, how much easier will a plug change be?
#8 Is open for debate weather you go from top or bottom, either way alot more room on pass side regardless because of AIR and EGR removal.
Drivers side gets some improvement too but only from some AIR hose and parts.
I didn't remove my coil packs but I did do a header swap. The stock manifolds looked like a nightmare for a change. LT's will definately make it easier.
See before (RIGHT TWO) and after (LEFT TWO)
I started with that and have since removed the ac, HVAC, relocated the wires on passenger side and relocated the coil packs. The drivers side is to cluttered now, i need to delete the ABS block. Its becomes addictive but my engine bay has so much room its not even funny.. Good Luck
Originally Posted by 2000BLKSupersport
what is the purpose of removeing egr and air?
