converting ls1 intake to fast intake????
Yes, you will need the front coolant pipe, 2 rear coolant plugs, I would suggest a new tb gasket if changing that as well. The FAST I bought didn't come with bolts for the TB and if you break the oil pressure sending unit like I did, then you will need a new one (from AutoZone like $40) and a oil pressure sending unit socket (~$4). Aside from that, just all the tools you can find and expect a lot of scratches from the cowl. I looked like I got attacked by a cat after I was done.
