FAST LSX 90MM System
Old 01-17-2006, 07:58 PM
LS1BlackBird99's Avatar
Default FAST LSX 90MM System
I know that the swap will require the coolant plugs and crossover pipe but will this require the 4 seals that the LS6 intake does or are the seals already built into the FAST intake?
Old 01-17-2006, 08:36 PM
TA TECH's Avatar
It will reqiure all the gaskets the ones you can buy from fast are thicker! I bought all the gaskets they sell the tb gasket to!But yeah they are made the same way!
Old 01-17-2006, 10:52 PM
So you're saying it is seperate? No gaskets come with it at all?
Old 01-17-2006, 11:26 PM
I just want to find a local place that will have the seals that I will need. Comp Cams is in town so I was hoping they would have what I need. If not, I hope the GM dealership might...
Old 01-18-2006, 12:07 AM
TINKRD's Avatar
i ordered the intake seals from fast. They came in a COMP CAM bag. So you should be safe going directly to them
Comp Cams
LSX LS1 Replacement intake port seals
part # 54009-8
Old 01-18-2006, 07:35 AM
slow trap's Avatar
i reused my stockers but only because i forgot to order the gaskets and was in a hurry.i would reccomend new gaskets.
