HOPE I DIDNT LOOSSE HP( no cut out vrs bullet
well what i wanted to do was save some weight so what i did was cut my cut out off and my cat back and i mounented a bullet racing muffler in the I pipe so i goes directly after the y pipe splits into 1......
i used to have a full cat back and a cut out next to the right tire do you all think i lost hp by doing this?? keep in mind the bullet flows straight through with 3 inch hole all the way through!!
now i am thinkin about buying another cut out and another y pipe because i found out mine is only 2 1/2 inches till it hits the i then 3 inches... i want to put my 3 inch cut out i previously cut out right after the left header and buy another cut out and put it after the right header and keep the same set up with the bullet!
what do you all think??
Originally Posted by Order 66
All depends, does the bullet have the have any obstruction like louvers or is it perforated(sp). Cause if its louvered then it would be a little restictive.
