Please Help
Old 01-23-2006, 09:04 PM
Juiced2001TransAm's Avatar
Default Please Help
I have Flowtech LT's,ORY, and loudmouth, as I found out, not a good combo. Sounds reallyyyy raspy. Is there a muffler that I can replace the loudmouth with that will sound awesome??
Thanks
Dan
Old 01-23-2006, 09:36 PM
SSU's Drunk Typing Whore
Lithium's Avatar
https://ls1tech.com/forums/showthread.php?t=139142
Old 01-23-2006, 10:56 PM
MM98's Avatar
Hooker single in/dual out sounds good, but a hooker single in/single out sounds freakin' mean... You can also add a flowmaster y-collector to your y-pipe to help out with the rasp as well.
Mike
Old 01-24-2006, 06:17 AM
300bhp/ton's Avatar
Thanks
Dan
Depends what you mean by awesome as every one has different tastes.
Basically any muffler that flows sufficently and is the same/similar size as the LM resonator should fit in place of it. Or you could use multiple mufflers for a more toned sound, or a combo of the LM resonator and a muffler.
Borla & Dynomax seem the popular choices however I like the idea of Magnaflow. None of these straight thru mufflers will make it any quieter but they will alter the sound. If you want quieter you'lll need a larger bodies muffler or multiple mufflers.
http://www.magnaflow.com/02product/s...ne=main&id=660
Old 01-24-2006, 08:39 AM
Benjamin Russick's Avatar
Was in a similar dilemma and the DynoMax bullet install didn't help a bit. I've since welded in a Borla XR1 and the difference is amazing. Get the Borla!
