wiring - AC wiring
Old 01-27-2006, 08:55 AM
smokinHawk's Avatar
Default wiring - AC wiring
ok im rewiring my car, over the past year on my turbo instal i realy went nuts.
trying to hook back up all the connectors.
there are three plugs im not sure where they go, might have to do with the AC. some might have to do witht the EGR which i removed.
how many wires get plugged into the AC one or two?
can anyone describe what they look like if they remember?
two of the plugs i cant remember where they go have factory foil wrapped around them b all three are on the passenger side on the engine bay, one wrapped in foil comes from the injector harness, the other 2 come from the far passengerside harness
Old 01-27-2006, 09:32 AM
smokinHawk's Avatar
i just remembered the ac dryer canister has a plug hook up that leaves two connectors (and at least one goes to the ac)
Old 01-27-2006, 09:34 AM
John_D.'s Avatar
The foil one from the injector harness goes to the a/c clutch.
There is a foil wrapped wire in the back on the side, that goes to the abs sensor on that side. That may be one of them too.
Old 01-27-2006, 12:49 PM
smokinHawk's Avatar
might be, thanks i think i might have forgotten to plug that one in after the kmember swap.
strangly those two that are wrapped with foil plug into each other.
might get luck and be able to start up my car tomorrow, only 1.5 years since i shut it off.
