90mm TB on a Truck
Old 01-30-2006, 01:53 PM
Super Hulk Smash
JakeFusion's Avatar
Default 90mm TB on a Truck
I have been wondering about this for quite a while, so instead of joining the affiliate forum, I'd rather ask here.
Is it possible to run a 90mm throttle-body (NW for F-Body) on a pre-2003 GM truck? I know in 2003 it was switched to a drive-by-wire system, but before that it was a cable, I believe. But, can it be used?
Thanks!
Old 02-03-2006, 10:20 PM
WILWAXU's Avatar
Too bad, it's a great question for the Truck site
If you swap the car intake (FAST) setup to the truck, you should be able to run what you want.
