plug wire ?ssssss help
I am in the process of coverting from lt1 opti junk to ls1 coil per cylinder I was wondering I need to run all 90degree boots on both ends if possible custom fit wires any buddy make such a thing???pics or help appreciated thanks
Originally Posted by SUX2BU
how are you getting that to work? aftermarket computer?
Yes I am in the process of installing my big stuff 3 it is actually a ls1 computer and wiring harness should be pretty trick setup have my coils mounted and crank triger mounted just have to figure what wires will be long enough to work.Plus lingenfelter sells a ls1 coil conversion that uses the opti sprak just for the cam signal peace.
