Cut out question......
If i put dual cutouts it will obviously decrease backpressure.... will it do any damage to valves?? some guy brought that up to me and was just wondering.... couldnt find anything on the search.....
I ran one for like 2 years and never had any problems, ran is year round. It was located under the passenger, on yht straight pipe after the Y. I assume if it was too close it could, but i have also ran headers with extensions with no problems. We live in texas remember, its cold like 6 days of the year!
just make sure they are behind the o2 sensors and you'll be ok, if the o2 sensor does not get a proper reading than u risk damage from over lean/rich conditions
Are you talking about using O2 sims for the fronts? If so I would strongly reccomend that you don't. You will be asking for nothing but problems since your cpu won't be able to regulate A/F ratio.
