electric cutout installation help
Old 02-10-2006, 04:36 PM
JB151's Avatar
Default electric cutout installation help
How do I wire this thing up?? It says the red wire should connect to the traction control wire (pink) how do I do this?
Old 02-10-2006, 04:40 PM
jmm98LS1's Avatar
You can splice into any switched 12v source (pink wires) under the dash. Just find one under the steering column cover and tap into it. That's how I wired my cutout when I had one and didn't have any problems. Good luck!
Old 02-10-2006, 04:44 PM
2001NBMZ28's Avatar
I extended the red wire and connected it to the radio fuse, for ground used the black wire off the cig lighter.
Old 02-10-2006, 04:51 PM
ta981's Avatar
you can use the red wire coming from the cig. lighter for the 12v.
Old 02-10-2006, 04:59 PM
bowtieman81's Avatar
I used an empty fuse block in the panel on the drivers side of the dash. I would probably not tap into the TCS wiring.
Quick Reply: electric cutout installation help
