Does porting the maf lean out a/f ratio?
Short answer yes you will run lean, enough to cause problems is a maybe/most likely depending on you setup, for the long answer read this or search this forum
Search.
Short answer: DO NOT TOUCH THE MAF.
If you think it is running off get it on a dyno and find out what the air-fuel ratio is, and if it is off go from there with some tuning.
Originally Posted by BLK02TA
What if you bought the car with a descreen MAF?
