Portmatching a Victor Jr
Old 04-04-2006, 03:53 PM
93LS1RX7's Avatar
Default Portmatching a Victor Jr
How do you port match a victor Jr intake to heads on an LS1. It uses orings instead of a gasket so I cant gasket match it.
Whats the trick you smart guys use?
Should I just buy a piece of gasket and cut oout the ports on the heads? Or is there some other trick to this?
Also how much "smoothing" of the runners should someone do? Just knock off the cast bumps? Is there such a thing as "too smooth" on the intake runner?
Thanks
