Fast Intake gaskets okay to run on LS6?
Old 04-13-2006, 08:25 AM
LS1FIRE's Avatar
Default Fast Intake gaskets okay to run on LS6?
Hello yall i am getting the P0107 Code and plan on taking the intake off to inspect things. I plan on changing the intake manifold gaskets as well. Will the Fast ones work without any problems on a LS6 intake?
Old 04-13-2006, 09:44 AM
daryl2cb@yahoo.com's Avatar
Yes they are the same, they should be fine, but I am guessing you have those around, and are not buying them, if you need a set, go to car quest, they are good quaility and really cheap.
Old 04-14-2006, 06:38 PM
LS1FIRE's Avatar
So is it bettter to run the fast ones with the ls6 intake our should i order some GM ones?
Old 04-14-2006, 06:50 PM
That's what she said...
TheBlurLS1's Avatar
GM ones are too expensive. BuynSpeed has them for like $32. I oredered a set last week and have them now.
Plus the are red, and red means fastttttttttttt.
Old 04-15-2006, 04:30 AM
35th SS's Avatar
Damm Chris.get you a fast intake/nw tb already.got mine finally installed today.
Old 04-15-2006, 05:07 AM
LS1FIRE's Avatar
Cool man.
Does it feel better? Also is the intake noise louder?
Take care man.
Old 04-15-2006, 01:03 PM
35th SS's Avatar
still have to calibrate for the 42pounds inj. via ls1 edit.will be running next week.
