Swapped heads, intake and T.B. Now....
Car is hesitating and thowing MAF, MAP, TPS codes. Everything is pluged in and I double checked. I even made a bracket for the MAP sensor on back of the LSX intake. Could it just be it needs tunning. I drove it from Oceanside to Miramar (30 miles) and when ever I got on the gas like up a hill, it would backfire and slowly acclelerate. Any ideas from the Gurus? I am supposed to dyno tune tomorrow.
Fig
Fig
Guy's it is on the dyno as I sit here and type. So enough about the damn dyno tune. When you add heads, intake and larger throttle body the engine should lean out. It did not, it is running rich. which is washing the cylinder wall out and causing hessitation and misfire. I ran the codes and it showed,MAF<MAP and TPS. If there is anyone out there with experiences like this after a had swap, please chime in.
Fig
Fig
