odd noise....
odd noise....
Ok... I have long tubes and ORY... and when I had stock muffler on there *with a cut out* never heard this... I then added a SLP LM.... and now, like when you let out the clutch and you dont over rev the hell out of it... or when the motor is cold and you let off the gas at about 2.5k... you hear this ehhhhhhh crazy *** noise... sounds like something is hittin under the car REALLLLLLY fast.... is the pipe where it runs over the axle hittin? sounds like its right under either the passenger seeat or the passenger rear seat... any ideas how to test and fix?
That's what she said...
After a few weeks of driving, there should be an obvious rub-mark. Might want to check your tranny mount also. I though my posi unit was going out in my old 10-bolt, turned out to be the trans mount.
99% of people's exhaust hits under the driverside floorboard.
whats that thing that is about 18 inches long... goes right over the pipe after the Y... looks like it would be some kind of reinforcement for something... thats what the pipe is resting on...
