Battery relocation problem help
I relocated my battery to the back and now when ever I start my car the pcm resets as if the battery was disconected. You know when all the instruments go crazy when you start the car. The car will still start every time with out a problem but still resets. I grounded it to my frame and its a good ground but I was thinking maybe I need to run a wire from the ground to my block or to the original ground. I checked my power wire to make sure its not grounding out and its not its fine. Please help it anoying the hell out of me. Thanks!
