ASP pulley question?
Old 03-02-2003, 09:23 PM
Z 2 L8ter's Avatar
Default ASP pulley question?
I installed the pulley about a month ago and decided to fire the car up the other day just to listen to it run. When it turned on the check gages light was on also. I went outside and saw the bigger belt that goes around the water etc. had flown right off. I put it on again and it worked fine. Has anyone else had any problems with their belts coming off with this pulley?
Thanks,
Jeremy
Old 03-02-2003, 09:50 PM
Jabroni's Avatar
Default Re: ASP pulley question?
If the balancer pulley is seated completely, I'd be looking at the tensioner pulley up top. I think I read here before about something called a "Larry pulley" that has a higher lip edge for the tensioner which will help the belt track. Do a search for a larry pulley and see if the thread pops up. In short, this has been an issue before.
Old 03-03-2003, 04:06 AM
DaddySS's Avatar
You may have just had a problem where the belt stuck to the pulley because it was sitting? If it's tight and aligned it should not come off.
