Does SLP's Flow Pac Eliminate the SS Hood?
I believe it's called a flowpac that has the metal duct that goes in front of the radiator and gets air from below the car. Does this eliminate the stock intake design of an SS camaro? Or does it use the cold air drawn from the bottom with the air that comes in from the hood. I know the cold air from the bottom is alot better than what little comes through the scoops. Thanks Brandon.
