question about BBK
question about BBK
I just bought one and found out that there is no hole in the plate! my car has stock internals so I wanna know for now should I drill one, and what size should I use if so?
Thanks,
Thanks,
Re: question about BBK
you do not have to drill a hole in the blade. Check your iac's with a scanner and open the blade with the set screw till you get 30-50 iac's(with the car warm).
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Venkman:
<strong> BBK what? Throttle body? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">YES!!! <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2002snortbird:
<strong> you do not have to drill a hole in the blade. Check your iac's with a scanner and open the blade with the set screw till you get 30-50 iac's(with the car warm). </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have autotap if that what u mean by scanner.
where to get that readings from? iac? so any reading between 30-50 is valid??
Thanks again....
Thanks again....
