FTRA or Ram Air?
FTRA or Ram Air?
I recently purchased a functional WS6 style hood and a friend gave me his WS6 Lower Airbox (he upgraded to the stealth box) I currenly have the fast toys ram air scoop on it with the stock lower airbox.
Is there going to be a difference in power between the two?
Thanks in advance.
Thanks in advance.
Re: FTRA or Ram Air?
I'm assuming that by "functional", you just mean that it really has openings in the nostrils. This is *not* comparable in performance to the FTRA. To get a 'true' ram-air for the WS6 style hood, you need to get the BG Ram Air - and that (I've heard) is just as good as the FTRA.
better? worse? I dunno... I'll probably go with the BG setup eventually though...
In your case, since you already have the FTRA, I'd just use that...
good luck,
Shane
good luck,
Shane
