FTRA/SSRA Fit With Trans Cooler?
Old 06-15-2006, 09:13 AM
Slvr98z28's Avatar
Default FTRA/SSRA Fit With Trans Cooler?
I am wondering if there are any of the kits, ftra, ssra, slp that fit with my trans cooler.
Old 06-15-2006, 09:53 AM
12secSS's Avatar
The FTRA and SSRA will interfere with the trans cooler, the SLP unit may work depending on the size cooler you select. I have an FTRA (less the deflecter shield) and a B&M cooler installed in front of the radiator, it is a tight fit. I am considering swapping to a fan/cooler combo and relocate the trans cooler to allow more cool air to enter the engine/radiator.
Old 06-15-2006, 11:56 AM
v8hunter's Avatar
I put my tranny cooler between my ac condenser and my radiator...you just need to get a one that will fit (not the b&m 24k). There is also another way of mounting it that is called "dope style" I'm sure someone else will chime in and explain, but to simplify you mount the cooler horizontal rather than vertical.
Old 06-15-2006, 01:05 PM
you2slo's Avatar
Go to the auto tranny section and search "dope style". All the info you need.
Quick Reply: FTRA/SSRA Fit With Trans Cooler?
