Pacesetters with cats on y pipe
Old 06-15-2006, 05:12 PM
dirtbag's Avatar
Default Pacesetters with cats on y pipe
Does pacesetter make a emmissions legal y-pipe? I have only seen ORY's. I want to get the pacesetters becuase of the cheap price, but I need a y-pipe that has cats on it for emmissions... Thanks.
Also, if there are any other compatible y-pipes, that would work also.
Old 06-15-2006, 08:30 PM
mrhzk35404's Avatar
There are no emmissions legal long tubes. You can get a tsp catted y pipe.
Old 06-16-2006, 10:33 AM
That's what she said...
TheBlurLS1's Avatar
I passed "emissions" here in texas with cats welded into my duals, so depending on where you are, you will most likely be able to pass with longtubes. TSP catted-y pipes are was 90% of people run with pacesetters, they take some time to get adjusted right however.
Like I do with everyone who is about to buy some headers, I'll go ahead and recommend poly motor mounts while you have the exhaust out. You'll be able to run the y-pipe closer to the floorboard without it hitting when you gas it. We have a sticky about this and lots of threads you could search for.
Old 06-16-2006, 10:39 AM
300bhp/ton's Avatar
+1 for Texas Speed & Performance catted Y
+1 for poly motor mounts (Thunder Racing)
Also I'd do poly tranny mount at the same time and get the Mufflex Y pipe hanger both available from Thunder Racing.
