LT's + an e-cutout...
In Need of Cup Holders!
Can I have long tubes with the regular stock exhaust, but just put a cutout before the cats? Is that possible? I dont know much about cutouts. Thanks!
Originally Posted by HeapaShifter
You can't have long tubes with the stock y-pipe.
You can do longtubes, aftermarket y-pipe, cutout, stock catback.
Do not run the stock cat-back, it is a major restriction even on an otherwise stock vehicle. Only run it if you are very determined to have the ultimate sleeper. There are a few cat-backs that flow well yet are pretty quiet, especially if you run high flow cats. SLP dual/dual, Hooker and Magnaflow.
Man, holy run-on.
Originally Posted by LukePhillips
Could I get LT's with whatever Y pipe matches them, then find whatever aftermarket system I can find for the cheapest and put that on to be used when the cutout is closed.
Man, holy run-on.
Man, holy run-on.
If by "aftermarket system" you mean a cat-back, yes then. You need to match the Y-pipe to the headers but any and every Y-pipe should match up to any and every cat-back.
I recommend hooker. The tips look alright, it's not very loud, flows well (should make plenty of power through it) and is inexpensive. <$300 last I checked.
