What should I dyno?
Re: What should I dyno?
Hey Tim, does your car wheel hop at all on hard acceleration? My six speed did and I also had alot of movement from trans. (you can see shifter move sideways on acceleration). I installed tubular rear lower control arms with polyurethane bushings to eliminate the wheel hop and the polyurethane trans mount helped out the other concern. This would be a good mod. to consider next.
01redws6ta 6 speed
mods:
SLP air lid
K&N air filter
SLP smooth bellows
Descreened stock MAF sensor
SLP 160 degree thermostat
SLP manual fan control switch
SLP Y-pipe
Flo-pro muffler
Lakewood lower control arms (rear)
Polyurethane trans. mount
Polyurethane torque arm mount
Skip Shift Eliminator
01redws6ta 6 speed
mods:
SLP air lid
K&N air filter
SLP smooth bellows
SLP Y-pipe
Flo-pro muffler
