Single fan, manual fan switch help
Have a switch with power, load, and ground. Ground is there because of the LED on the switch. I have the power to the switch tapped off the cigarette adapter, so it's not hot all the time. Now for the load, do I just tap it straight into the power wire for the fan? I still want it to work on it's own through the stock relay as well. Any ideas?
