the new GM trans fluid in my PS pump???
i was filling up my 6 speed and the guy at the dealership told me i could also use the new (ATF VI i think) in my power steering pump is there any truth to this? it looks as if the viscosity is not the same as in PS fluid (thicker) let me know any info ASAP thanks guys
I have used trans fluid in the power steering fluid on plenty of cars. It will not know the difference. They are both a petroleum based product. However on my trans am since I know it has ps fluid in it I just put ps fluid in it and i usually just have to add a small amount. Most of the times i have run trans fluid it has been after the fluid has been drained and not in a rack and pinion car. But if the guy at the dealership told you then there must be some truth to it.
