Remove LS6 Intake connection?
I'm starting work on the LS6 intake paint job, got the intake stripped down and ready to start sanding. The vacuum fitting in the back of the intake can be moved a little but nothing I've done has been able to remove the fitting.
Is it removeable? If so, how do I do it?
Thanks,
Mike R.
Thanks,
Mike R.
Originally Posted by TheBlurLS1
I think he wants to remove the whole thing (brake booster and a/c vacuum fitting part). I'm not sure how you remove it, but I'd just pull the MAP sensor (unclip-pull up), tape off the vacuum ports, and paint it.
