tsp true duals
yes..I have emissions visual...no tail pipe testing. stock manifolds and cats...i'm more worried about sound then getting anymore power. I have the reg rumbler right now. what is the quietest straight through muffler that couold be done on true duals?
You could probably take the TSP duals and have a shop make a custom pipe that will go from the cats to the dual setup. I havent seen it done, but I am sure it can be done, all they have to do is bend 2 pipes and put flanges on both ends.
Spiral flows mufflers are nice, they sound great and are very tame when not on the gas hard.
The best mufflers would be MagnaFlows. Their straight through, noise cancelling design mufflers on dual pipes going over the axle and with one muffler located on each side of the rear tub then with both pipes going out the rear from beneath the bumper in their stock location. With the stock manifolds and stock catalytic converters and an "H" pipe, the MagnaFlows will give you a sound that is not loud, (as long as you press lightly on the loud peddle around town) but will give you a deep tone with that muscle car sound.
