Check Engine light on b/c of AIR. Reinstalled, won't go away??
Old 07-11-2006, 05:23 PM
Sick99WS6's Avatar
Default Check Engine light on b/c of AIR. Reinstalled, won't go away??
Just like the title says. I put the AIR back on, reset the computer (disconnected the battery for 5 min.) and turned it back on and it was still there. Any suggestions on how to get this to go away?
Old 07-11-2006, 05:32 PM
2001NBMZ28's Avatar
Not sure if just disconnecting the battery for 5 min alone without pulling the fuses with the ignition on will competely reset the PCM, what code(s) you throwing?
Old 07-11-2006, 05:35 PM
Sick99WS6's Avatar
Not sure what codes it is throwing b/c I dont have a scanner. How can I completely reset the PCM? I thought it was only by disconnecting the battery.
I know it is the AIR b/c that was my only mod to the car and the light came on right after removal.
Old 07-11-2006, 05:48 PM
2001NBMZ28's Avatar
PCM Reset:
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
If the light comes back on autozone will read it free.
Old 07-11-2006, 06:36 PM
Sick99WS6's Avatar
PCM Reset:
Wait 5-10 min
Turn ignition off
Replace fuses
Thanks!! It worked so I am all set.
